Dodgy card or not
1 Aug 2005
Not far from you!
Hi guys....can anyone tell me if this is a dodgy card....it does it at stock clocks with no mods either and make's continous sound same as when it finds an error....and is 1 week old. :(
if that was mine i'd RMA it right away if possible.
I think thats the sign of some dodgy ram. :(
Hi guys....and thanks for the reply's....about gaming...i have had a 5-10min game and is ok....i am a bit scared of giving it a good hour so just incase something fries....i asked on another site and someone sujjested could be overheating and another said to tick box inartifact scanning to use older compatable metod which i did give it 3 ten second run's ok closed it opened back up and here's what i got in pic....if i was to rma what do i tell them for a reason as obviosly they will test as ati tool is for ati cards?.
EDIT:Problem solved....driver issue even though did not occur when i swap cards the only difference is green pcb was ok... black pcb had this roblem this was with latest whql drivers....now gone back to 84.21...all's ok....thanks for all replie's
