17 Mar 2008 at 22:23 #1 aayzof aayzof Associate Joined 25 Dec 2006 Posts 954 Location UK .. Cheers. Last edited: 24 Feb 2009
17 Mar 2008 at 23:41 #2 gumbald gumbald Soldato Joined 26 Aug 2006 Posts 9,726 Location 62.156684,-49.781113 They should be able to sort it on the spot if they're happy. Might want to send it off if they're concerned it might happen to others though.
18 Mar 2008 at 02:05 #3 iSam iSam Soldato Joined 12 Aug 2004 Posts 6,105 Sometimes the light on my charger won't work. But if it has stopped working and there is visible damage then take it straight back to Apple and they will sort it for you.
18 Mar 2008 at 09:35 #4 Deleted member 651465 Deleted member 651465 There was a recall / problem with the newer smaller adapters. Frankly, if the prongs are stuck in the MacBook then I'd demand a replacement (obviously if it's within the first 28 days)
20 Mar 2008 at 22:54 #5 aayzof aayzof Associate OP Joined 25 Dec 2006 Posts 954 Location UK .. Last edited: 24 Feb 2009
