Dodo wax
i find my hard dodo wax quite hard going but i get a good finish.
big fan of Collinite No. 476S - Super Doublecoat Auto Wax for the winter though last ages and ages
its meant to be awesome! if the weather perks up i might buy some to sort out my car. its looking a bit dull and lifeless
I use Dodo Juice Banana Armour on mine (hard wax). Seems very good, suited to warmer coloured cars. You do need to build up a few layers though.
You can guess what it smells of too... :p
Yeh its really good, just had my car detailed and he used this stuff on my car and the finish is brilliant. The cars paint was really dull before it was done and now it look 100x better
It's fantastic stuff and does smell great. Blue velvet on a dark car gives an excellent finish and protection.
Highly rated on the Detailing World forums...never tried it myself, I prefer:
1. P21S
2. NXT Tech wax (Megs)
3. Aqua-wax
4. Harley wax
One on top of another, over and over again :D
Just out of interest, why would you use a polish/wax hybrid (NXT) after a layer of wax (P21S)?
i use Finish Kare 1000P
pretty awesome results i must say :)
Hi Temp Synthetic Paste Wax
Developed from a West German process called Synthesis 1000P is a blend of advanced pure synthetic materials. The result is a paste wax characterized by melting temps. of 250+ degrees, extreme hardness, extreme slickness, high gloss, and intensive wear without the quality fluctuations found in natural waxes. 1000P delivers heavy duty resistance to UV, hard water, acid rain, bug spatter, tree sap etc while creating a customer appearance. Excellent for use on all automotive paint, gel coat and metal surfaces including critical aircraft surfaces.
http://www.fk1usa.com/products-consumer.htm
Its synthetic. No thanks.
I use Dodo Purple Haze. Its not very hard wearing but the depth of shine is just "wow". I used to use Poor Boys Petes #53, but the Dodo is miles better by comparison.
I also have the £65 plastic tup version of the dodo supernatural V2 for the real show off times. That is serious. No colours or fragrances makes it as pure as you're likely to get.
