Does 600 build a decent pc with Monitor and Kb/Mouse etc?
18 Oct 2002
Somewhere in the middle.
I have been asked by someone at work to spec/build/recommend a PC for £600
He mainly just wants it for general usage and gaming is not massively important. However I imagine he would expect it to play games to a reasonable level.
With a monitor around 20-23inch.
Sorry if this kind of thing gets done to death. Ive seen a bunch of specs while trawling the threads but few have monitors and peripherals.
Any input appreciated.
Thanks!
I plan on ordering this at lunch time today. I notice no GFX card was included in that spec list.
Ill remove the SSD as I dont think he needs one right now (can be added later) and Ill only use the one 500gb drive.
The Rest looks good. What made the Viper ram a good choice? is there cheaper alternatives so I can up the gfx card budget?
I altered the spec to only have the one 500gb hard drive. I added an LG optical drive and I swapped the ram for 4gb of kingston genesis. Then I added a 7850 2gb gfx card.
Came to about 650 all in.
Just seems the PSU wasnt in stock which I didnt realise til I had clicked confirm order. Hope that doesnt delay things.
