Does a Arctic Freezer II 280mm AIO fit into a Phanteks P400A case?
25 Aug 2020
I’d like to buy the Arctic Freezer II 280mm AIO but, having read various reviews, I understand that its radiator is particularly beefy and the entire unit measures c. 65mm in thickness.
This means that, if mounted at the top of a computer case, it requires c. 70mm of clearance above the motherboard to fit.
I'd like to buy a Phanteks P400A but I need to check whether this case has sufficient clearance above the motherboard for this cooler.
Anyone got any ideas?
As I understand it the P400, P400S and P400A all share the same frame and layout.
I have the P400S.
In my case there isn't space for a 25mm thick rad up top, much less a 65mm one.
There may be space in the front; if you're interested I can measure this for you?
