Just wondering, do you need insurance on the car being towed?
The towing car has insurance but does what about the other car.
yes
unless it's on a trailer, or the car is attached using an A bar.
I was always under the impression that as with the TAX if any wheels are touching the ground in needed to be insured. A full lift or trailer are the only legal way to transport it.
[TW]Fox;13647326 said:Surely you mean a Frame not a Bar?
an A-Bar I mean.
An A-frame or dolly can only be used to recover a broken down vehicle to a place of safety. Transporting a car is, therefore, illegal. A-frames may be offered with a braking system that applies the car's brakes. These do not conform to the law as the car then becomes a "braked trailer" and has to conform to European Directives contained within the Construction and Use Regulations. It does not conform to the European Directive 71/320/EEC and amendments regarding braking requirements in any way. The use of this A-frame for transportation is illegal.
yes
Well yeah you would have to have a way to apply the breaks without a person being in the car as well.
Basically it's not practical at all.
Well yeah you would have to have a way to apply the breaks without a person being in the car as well. Basically it's not practical at all.
A bar doesn't have to be just a bar, even though that is what the name implies.
[TW]Fox;13647370 said:No, because then it would be a braked trailer which has various different construction and use regs pertaining to it, which it wouldn't meet, so this is completely wrong as well.
By 'not practical' you mean 'illegal and not possible'.
Why is everything you ever post the complete opposite of whats true
It's not. I know using the A-bar/frame would make it classed as a trailer. That is the point, that is why you wouldn't need insurance/tax on it. Providing it wasn't too heavy for what your license allows you to tow it would be fine.
[TW]Fox;13647401 said:This is like talking to a brick wall.
You cannot tow using an A-frame. You can only recover a vehicle to a place of safety. It really is that simple - towing a car using an A frame is illegal.
It's not if you basically convert the car into a trailer.
I think yantorsen should be banned from dishing out motoring advice, its getting a bit silly now seeing wrong advice given out in every thread as if its truth.
Like I said though it isn't practical at all, I just said it as a random point.
What you on about, apart from in this thread, where I haven't given out wrong advice, I never give out advice.
[TW]Fox;13647424 said:You can't just 'basically convert a car into a trailer', what on earth are you talking about? Besides, it would be more than 750kg so over the unbraked trailer limit anyway, thus guess what, illegal, fancy that.
[im]http://img239.imageshack.us/img239/5641/unbenanntyx2.png[/img]
oh come off it, i've seen quite a few threads in the past week where you have said some sillly things which just aren't true.
