Does a GPU help with photo and video editing?
Man of Honour
18 Oct 2002
UK
I'm currently working on a repurposed Dell Optiplex 7000 MT. Specs are:
i7-12700
32Gb DDR5 RAM
Intel UHD 770 graphics
2x 2Gb NVME
I use Lightroom Classic & Photoshop for photo editing, and Premiere Elements for video. I also occasionally use Handbrake for encoding.
Firstly, I'm fairly happy with the performance in general, but would adding a GPU to the system make it run smoother? I have recently upgraded to a 40mp camera and the larger files do make it run a little slower, especially when processing higher volumes. Things like AI denoise when I occasionaly use it also take a bit longer.
I normally process video in 1080p but would like to move to 4k, and this is where there is a very noticeable difference in performance. Would a GPU help here?
Secondly, would a GPU that my 260W PSU can support (no additonal power connector required) such as an RTX 3050 be worth it?
2D stuff used to be always a CPU thing, but the newer versions of Adobe definitely do use the GPU a lot more, particularly for the AI features. From what I'm aware of, this is still a case-by-case thing, not every feature does, so it depends on usage.
In so far as, how a 3050 would stack up against the 770, I don't know.
you're a bit limited options wise with your available power to do anything meaty, but a dedicated GPU can certainly help with encoding.
I've ordered a RTX 3050 6GB to see how it runs. Doesn't require additional PSU connection and under £150. It has to be better than the integrated graphics!
Arc B570? It has the same Encode/Decode performance as the B580 and benchmarks have it using the same ~130W as the RTX3050, which doesn't have an AV1 encoder by the way.
Edit - If you can find the Lite-On L500EPS-01 or D500EPS-01 (not sure of the difference) it seems to be the go-to 500W PSU upgrade for that box. Dell part number VFFKJ
Yes it completely helps, the better the GPU the better the acceleration, at least an RTX 40 series card gets you at least 1x AV1 hardware encoder as well, whereas a 4080 or above gets you two or more. Either way, GPU acceleration is now done in Lightroom even for 1:1 preview generation which speeds up preview gen considerably. Going from an RTX 3080 Ti to 4090 took my Lightroom batch exports from ~40 mins on average to around 12 mins maximum for similar batches.
Handbrake supports NVENC for H264/265 and AV1 so all good there, I use Davinci Resolve for video editing though and that too supports NVENC and typically a 4K 60fps video encodes to AV1 at 84fps depending on specific parameters chosen but typically Q value of 26, FLAC audio, constant framerate and tuning set to highest quality.
Yes my new M4 Pro MBP cuts through rendering 1:1 DNG previews in Lighroom like a knife through butter. The entire experience blows my mind tbh but I did come from an iPad Pro which is absolute turd for content creation.
