Get annoyed when people refer to their systems as water cooled but they are just using a closed loop CPU cooler?
I think they should call them something else
- Grumpy *******
Does'nt really annoy me although the only time when it does get on my nerves a little is in sales advertisments, when its listed as a 'watercooled' gaming rig. Although technically its correct, but to us high end gamers etc it isnt.
Does anyone even use water?
They should all be re-named liquid cooling.
Technically the closed loop systems are water cooled. They use water as a means to transport heat away which is just the same as watercooling used in cars etc. and not really different from a custom made water cooling setup. Really the only difference is: you don't have any assembly to do (other than installing it), the pump and cold plate are directly attached and the radiator and reservoir are one. It still has everything a custom loop has most importantly they both have water.
