Does anyone have a 1440p, 144/165 Hz monitor?
25 Sep 2011
United Kingdom
I currently have 2x identical 25" 1440p monitors 60 Hz monitors.
I want to add a high refresh rate 1440p monitor between them.
I'm hoping for the heights of them all to be as similar as possible.
However, there are hardly any (if any) 25" 1440p high refresh rate monitors.
Does anyone have any of the following?
  • Acer XB241YU (24")
  • Acer XB271HUABMIPRZ (27")
  • Acer XF240YUBMIIDPRZX (24")
  • Acer XF270HUABMIIDPRZX (27")
  • Acer XG270HUOMIDPX (27")
  • AOC AG241QG (24")
  • AOC AG241QX (24")
  • AOC AG271QX (27")
  • Asus MG278Q (27")
  • Asus MG279Q (27")
  • Dell S2417DG (24")
  • Iiyama GB2760QSU-B1 (27")
  • Samsung C27HG70 (27")
  • Zowie XL2730 (27")
  • Zowie XL2735 (27")
If so, could you possibly measure the height of the screen in two ways, for me?
  1. The height including panel casing (but not including the stand etc.)
  2. Just the panel height itself (so should be a little shorter than the above)
This would be very much appreciated, as it's very hard to get heights online!
Well when you know the diagonal measurement of the monitor and the aspect ratio (these all seem to be 16:9) then finding the height is basic trigonometry.
Or alternatively google 'Display Wars' and that will give you all panel measurements you require.
