Does anyone have an UltimateEars Hyperboom?
5 Jun 2007
extremes.spacious.indelible
Hey all,
A very weird request this one!
Does anyone have an UE wireless speaker that when it has low battery says "Critical Battery, Please Charge."
I want to try and get this as a sample for a song I want to make for a joke friends present.
Have searched high and low for a video of it coming out of the speaker online but can't find it anywhere, and the friend with this speaker is in Australia and doesn't have the gear needed to get a good recording :o
Always worth asking a weird question on OcUK! :p
Are you able to obtain the actual audio clip from the firmware for the device?
As @VincentHanna says, I don’t have one and don’t fancy dropping £400 on one just for the sample for a jokey present :p
Do you think it would be possible to extract the Audio from a firmware file if I can find one online?
EDIT: I've found the firmware and extracted using 7Zip, but can't see any audio files in there, lots of JS files and other random stuff unfortunately.
Are the audio files likely to be "hidden" inside one of these?
Sorry yeah what I meant was from a firmware file online.
You might need a major release version, don’t know if the incremental updates would have everything.
Hey all,
Hi @Megahurtz400 - I've recorded the sound clip. How can I get it to you?
