- 25 Sep 2009
- Billericay, UK
Hi guys,
I recently bought a Lian Li PC-P50 Armoursuit case and a Foxconn BlackOps X48 motherboard along with some other parts (including the wrong type of ram
, thankfully overclockers will allow me to return it).
The problem I have is the Power LED plug on the case is a 3 hole plug wired as so;
[POS][empty][NEG]
However the pins on my new motherboard only has 2 pins available for the power LED so at the moment I can't wire it up. The simplest option I think would be to pull one of the wires out and move it across one hole however I've never done this before and I'm not sure how to go about it.
I've had a quick tug at the wire but it's fixed firmly in place, I've also a had a quick hunt around Google but I've really found anything that useful. I would appreciate any help you guys could give.
[POS][empty][NEG]
