cant you make a shield like the ones you get with the k&n kit?Retro fitting an engine with limited space, so may have to relocate the filters current position. Looks like it may need to go lower, increasing risk of puddles etc.. looking at giving "slight" extra protection.
After some googling I think I've found what you was looking for, although personally I would go for a sealed intake for maximum protection.
http://www.knfilters.com/search/wrap.aspx
