20 Nov 2008 at 12:55 #1 dvdbunny dvdbunny Permabanned Joined 20 Dec 2004 Posts 1,122 I am using azereus now called vuze and Just wonder where is the folder where it saves the torrent links to? Where is the temp folder?
20 Nov 2008 at 13:01 #2 Hamster Hamster Soldato Joined 25 Oct 2002 Posts 5,648 Location location: location Check somewhere in options. The directories should be listed there. If it's not then just search your pc for *.torrent.
20 Nov 2008 at 13:07 #3 Snakedoctor Snakedoctor Soldato Joined 13 Sep 2007 Posts 3,951 c:/Pogram Files/Azureus/I am a pirate/azureus downloads/
20 Nov 2008 at 14:57 #4 dvdbunny dvdbunny Permabanned OP Joined 20 Dec 2004 Posts 1,122 Snakedoctor said: c:/Pogram Files/Azureus/I am a pirate/azureus downloads/ Click to expand... I do not see any azeureus downloads folder? I have even enable hidden folders and still don't see it!
20 Nov 2008 at 16:05 #6 bledd bledd Don Joined 21 Oct 2002 Posts 46,858 Location Parts Unknown try outside
20 Nov 2008 at 16:12 #7 Matteysan Matteysan Soldato Joined 15 Nov 2004 Posts 5,997 Location Telford as i said in your other post C:\Documents and Settings\Username\Local Settings\ But I just said documents & settings. I'd seriously do what bledd has said countless times just format the damn thing.
20 Nov 2008 at 16:21 #8 mrk mrk Man of Honour Joined 18 Oct 2002 Posts 106,006 Location South Coast C:\Users\USER NAME\AppData\Roaming\uTorrent is where it is in vista for uTorrent.
20 Nov 2008 at 16:54 #9 CliffyG CliffyG Soldato Joined 18 Oct 2002 Posts 18,124 Location Cambridge Just click on start and run and type in %appdata% and click ok. Will prob be in there somewhere.
20 Nov 2008 at 17:01 #10 suarve suarve Soldato Joined 8 Oct 2005 Posts 4,184 Location Midlands, UK dvdbunny said: I am using azereus now called vuze and Just wonder where is the folder where it saves the torrent links to? Where is the temp folder? Click to expand... Dude, have you even bothered to try the most obvious places like the vuze support forum or google? I'm sure that would be way quicker???? Bless dvdbunny
