Does anyone run tri 7970's & Eyefinity
20 Jun 2009
UK
Im looking at getting a 3rd 7970 for my eyefinity setup but after the problems i had on my prev rig with 6970's im not so sure.. The main reason is BF3 but on my last rig it would run better with 2 cards and not 3. Thanks
Might get more responses if you post in the Graphics Cards section of the forum, not general hardware. From my experience I believe the more cards you add in CrossFire the less well they scale together well. Good luck and sorry I couldn't give much of a answer.
no prob, thanks :)
What's the frames like with two of them?
from what i can remember its been 3wks @ 5760x1200 max settings apart from AA on none i think! I was getting 80-120fps steady and more when in jets etc.. it kills my last 6970 trifire less bugs and a steady fps without any lag etc..
