Does anyone use a bigger portable screen for their Switch?
2 Jan 2004
Chesterfield
Before we begin, yes I know the Switch has it's own screen and yes I know you can plug it into your telly - what I'm after is something in between!
Basically my youngest uses the Switch while his brother uses the main TV for his Xbox. (They like to be in the same room!)
The problem is I'm not keen on him hunched over and so close to such a small screen so I'd like some sort of portable screen with a HDMI input that I can easily put it away when not in use.
Does such a gizmo exist???
Many options exist for this, I just recently got a 13" 1080p screen exactly for that reason. It fits neatly under my main PC screen and is mostly for Switch use.
Many can be powered direct by 5v USB and are very slim and easy to pack away with included folding cases that act as as stand as well.
Got an IPS with vsync/gsync for only £150 on sale, very happy with it for its purpose. Can also connect to a PC or laptop via usb c, mini display or HDMI.
I have a portable setup for my switch, which uses a 13.3 wimaxit M1332C ips screen powered off a ZMI QB820 PowerPack 20000. The screen has full size hmdi and can be powered from either usb c or usb micro. Works really well.
If it helps this is the model I got that includes a carry case.
13.3 Inch Portable Monitor, UPERFECT 1080 FHD Ultra-thin External Monitor, IPS Screen with Standard HDMI Type C OTG Mini DP, Eye Care Gaming Screen
Highly recommended.
