Does ATI crossfire work with TDU2
Caporegime
27 Nov 2005
Guernsey
Does anyone here have a crossfire setup and the TDU 2 game ??
As am just wondering what crossfire is working like with this game..
As this game SLI support totally sucks :( and wondering if you ATI crossfire guys are getting any better luck
Game probably uses a rendering technique (probably a post processing effect) that doesn't work well with the current multi GPU rendering methods (AFR/SFR).
I got this game to use both my 580 GPU's at 99% usage now
By setting to "SLI 16xAA" so my second card doing the AA work
Before
Gpu1 = 99% usage
GPU2 = 4% usage
Now with "SLI 16xAA" selected there both at 99% usage :)
So basically you are making the gpu's work by feeding it masses of aa work to do. I take it that your fps are still the same but your picture is great or am i missing something.
Yes your correct..
Think "SLI AA" means GPU2 does the AA (Maybe someone can comfirm )
Hopefully when they patch it you can have high fps with the same picture.
Went you select one the SLI AA options it disables normal SLI Mode
