Why are you worrying? You could upgrade your graphics card alone no problem, there are some excellent AGP deals out there such as the X1950 Pro which if you shop around can be had for the same price as the PCI-E versions (like this one: http://www.overclockers.co.uk/showproduct.php?prodid=GX-071-HT)I planned to upgrade my gfx card alone but its pci-express these days not AGP so I need a new MB aswell as my current is AGP only. My cpu is backwards compatible but will my old DDR ram work in the newer boards?.
Thanks.
A 754 or 939 Athlon 64 3400+ won't be able to use DDR2 (the integrated memory controller on those CPUs supports DDR only!) so even if you went for a new mobo there would be no new RAM needed.Damn, so its new mb, ram and gfx card otherwise dont bother :/.
My cpu is an amd 64 3400.
