Does Einstein@home....
Hi eggcup yeah it should work fine right from stock. Once you have it running if you want to alter the cpu or gpu ratio to have more than one task running its slightly different than other projects, you would have to go into the boinc data folder and edit the client_state.xml file
ah yes it using about 5% of the gpu at the mo, lol, where abouts in the file would i find the bit to change the ratio, sorry to be a pain
Hiya we all have to start somewhere i was where you are at not so long ago:)
Exit Boinc
Go to Boinc data folder
Open the client_state.xml file with notepad only
Next bit you can either scroll down untill you find the app info for the einstein cuda abp or on the top of notepad click edit-find and a small window pops up.
Enter the word count, this little box is just a search tool so whatever you type in it will find the first instance of it...hit return and it will find the 2nd and so on. Be sure that after you have entered the word "count" or whichever search term you want to use that the cursor on your main notepad window is at the beginning as it will only find the next instance etc - so if your cursor was half way down and you click enter your going to elliminate results that appear before the cursor.....you still with me:)
So you enter whatever search term you want i choose count or abp and it will take you to the einstein cuda app info you want to edit....do your stuff...save and exit notepad.
Restart Boinc and whatever options you have changed will be in force.
It does have the nasty habit of resetting each time it connects so you might have to do this over and over.
Best of luck Mr eggcup....will check back later....i have zombies to slaughter and some stuff to wrap :D
