Does Enermax Galaxy 850 fit in Antec P180?
19 Aug 2005
Ealing, London
As title really, done a bit of rough measuring and I think it'll be possible (just), just wanted info from anyone who knows for sure either way.
Many Thanks. :)
If the width is the same (which I'm guessing it is) then yes it will. I have fitted a silverstone 750f to the p180 which is longer than standard and that fits fine although I have also removed the bottom fan which may also be required in your case.
