I posted this in Hard Drives but have had no replies, so i thought i may have more luck here ...
Bought my first NAS recently, I know nothing about Linux and am a little confused about how EXT3 works.
Just using a basic drive setup at the moment as i couldn't afford to buy 4 new drives and needed to get 4x1tb drives out of my pc.
1st drive i formatted ext3 which created 3 partitions (100mb, 930gb and 500mb). I was only able to copy about 880gb to the drive leaving 50gb i couldnt use
2nd drive i also formatted to ext3 but when i put it in my pc to transfer data to it, there was only 1 partition and it was formatted as ext2.
I dont know what the first partition of on the first drive is, 2nd partition is obvious and 3rd is the swap drive. Is the missing 50gb reserved for something, and is that why the 2nd drive is setup up the way it is?
Is the 50gb reserved for recovery for all drives should a problem occur?
Cheers
Cheers
