Does it matter which DDR4 3600 Memory I use for a AMD 5900x?
28 Apr 2008
So over the past year I upgraded my pc to a AMD Ryzen 7 5900x, a MSI X570 Tomahawk motherboard and some G.Skill Trident Z F4-3600C18D-16GTZN memory.
My question is did I buy the correct memory kit for my motherboard and processor. I'm sure I read somewhere that the right RAM matters for Ryzen processors. So wanted to check if I have the correct RAM or if I am actually losing performance with the kit i am currently using.
The speed is good, timings are OK but you will be missing out on the slight boost from the RAM being single rank (I assume it is anyway with 2x8Gb modules) over dual rank sticks.
It's not worth changing RAM over.
