Does my AV receiver support 4K?
23 Mar 2019
I own a Pioneer VSX323 AV receiver and am thinking of upgrading to a 4K TV. Can anyone confirm if my receiver supports 4K resolution? Pioneer says it has 4K passthrough but I know that some receivers don't support 4K content with HDCP 2.2 protection. I bought the receiver in 2013.
If it doesn't support 4K, can anyone recommend a new AV receiver that would complement my current setup? I currently have Tannoy TFX 5.1 speakers and a BK Gemini subwoofer that are used for gaming, movies, and listening to vinyl records. Budget is around £200-£300.
Check the manual?
Alternatively plug your 4k source directly into TV, I had to do that as my receiver doesn't do 4k. Then I ARC sound from TV to receiver.
