Does my MB support 4 pole jacks?
11 Aug 2010
Hello
I'm looking at a new headset but it uses a single jack for in/out. It says that the PC will need a 3.5mm 4-pole jack in order to use it.
I tried looking at the specs of my MB but can't see anything so thought I'd ask on here.
My MB is the Gigabyte P55 UD3
Thanks
Yes you will need a 3.5mm connection to your motherboard and if you have a microphone on you headset you will need a splitter.
The headset im looking at has a microphone and uses a single 3.5mm jack.
So I'll need a splitter for single 3.5mm jack that then splits into 2x 3.5mm jacks making 1 jack for microphone and 1 for headset?
"StarTech 3.5mm 4 Pin to 2x 3 Pin 3.5mm Headset Splitter Adapter - F/M", found on the rainforest, seems to be what you're looking for. One goes into an output port, another goes into a microphone port, and then you connect the headset on the female side.
