Does my video card need additional power??
1 Aug 2003
I've got a gigabyte gv-n96tsl-1gi which I've been using with a 300w sfx psu. Included with the video card I got a 6 pin plug connector with two 4 pin molex psu plugs coming of it. I took this to mean that I should connect the connector to the single 6 pin plug on the card and plug the 2 molex plugs into my psus connectors..? So far so good it's been working fine.
However, I've just gone and brought a new 450w psu which should give me more head room. One of the connectors running off the psu is specifically marked as a pci-e 6 pin power connector and in fact there's 2 of them coming off the same lead. One has another small lead with an extra 2 pins to enable it to become a 8 pin connector.
Anyway my question is... how should I be connecting my video card up with this new psu!? I've checked its manual and basically it doesn't mention anything about additional power connectors? Should I even be adding extra power to the card? And if so should I be using 2 connectors or just one? Indeed if it's 2 how will I do that? Should I be looking to purchase a 6 pin to 2x6 pin adaptor or something!?
Any help on this would be greatly appreciated.
Just plug in as many 6 pin cables to the card as there are connectors.
This should be done for all cards.
Leaving empty power connectors on card will lead to one of two things:
1. Card uses safety clocks at all times and is really pants.
2. Card refuses to work
If you are talking about using an 8 pin in a 6 pin socket then the 2 extra pins are just ground, its mostly just cable ratings.
An 8 pin cable is rated for 150W, a 6 pin cable is rated for 75W.
However a computer only draws as much power as it needs.
EG:
A good quality 800W PSU and a good quality 600W PSU will hapily feed a computer consuming 400W, the PSU rating itself just needs to be greater than the actual draw. It is recommended to stay around 80-90% of the PSU when your computer is running furmark and a CPU stress test at the same time.
This:
A) Gives some breathing room as your computer will never use more power than this.
B) Makes sure your PSU is operating at its max efficientcy range.
With your new PSU all you require to attach to your video card is one of the 6 pin PCI-E power cables.
If your video card has a socket for a 6 pin PCI-E cable then it requires it to run properly.
if the card has an extra slot for power, then u really need to plug one in.
the 6pin from the psu will be fine.
some cards require 8 pin (more power) which is what the extra 2 pins are for from the psu. But if you card only has a 6pin slot, you can saftly ignore the extra 2 pins.
