Does Overclockers have better value PC builds than these?
13 Sep 2021
UK
My budget is a HARD £1150
Build 1
AMD RYZEN 5 3600 4.2GHz, RTX 3060 12GB, 16GB 3000MHz, 250GB SSD, 1TB hard drive, 600mps WiFi, windows 10
£1069
Build 2
AMD RYZEB 5 5600G Nvidia RTX 3060 12GB, 16GB RAM, 960GB SSD, 550W 80+ PSU, WIFI, WINDOWS 10, ONYXIA III RGB
£1136
*Wifi is important. Is there a build on Overclockers that is better value than these builds?
Without knowing the actual parts cases PSUs etc we cannot possibly say.
Build 2 makes no sense so do not go for that. If you have a GPU in the pc get a 5600x not 5600g.
What I've Seen if willing to shop
Ryzen 5 5600X £245
MSI B550 Gaming Edge Wifi £159.99 though MSI have a £15 casback offer on it so £145...board comes with wifi 6
My basket at Overclockers UK:
Total: £301.66 (includes shipping: £11.70)
above with other 2 you get elsewhere comes to £692..the psu can power a 3080, and with a 10yrs warranty will do your next upgrade too(it's on offer), or knock £10 off for the rm750.
That leaves £458 for a gpu, so either a 3060ti FE for £369, or get yourself a 6600XT, which is more powerful than the 3060, but sits below the 3060ti...you can pick up a windows key for under £10
