Does PCIe 2.0 bottleneck GPU performance
12 Nov 2011
Reading
I have recently upgraded my GPU to a EVGA 980 SC and am currently using it the 16x port of Asus P8Z68-M PRO. I think my stock 2500k is probably holding my pc back the most.
EVGA 980 shouldn't have any bottleneck running through a 16x PCIe 2.0 slot, you can check and confirm using GPUz that it is running at 16x though as a first check. 2500k shouldn't really hold you back, overclocking it to 4GHz fairly easily should be another part of your checklist if you're not already overclocking it.
