Id avoid the gelid connector, running to many fans of one header could be dangerous, the one ive linked above is much safer as power comes direct from the psu. I use it to power pwm fans on my rig, a much safer setup.
If only Akasa would braid their cable!i've currently got 6 apaches running off the cpu header, via 2 akasa pwm splitters sliced together.
bit of solder to link the pwm line to both splitter cables with a bit of shrink wrap around and you're sorted
i would post a pic but it's a bit messy in my case at the mo, and i'm a tad embarrassed![]()
