I'm moving the wifi router from my desk in my room to the hallway.
I have a voip fone connected via ethernet and a desktop PC in my room, which I'm going to hook up using 0.5M ethernet cable onto an unmanaged switch.
Then I'm going to hook up the switch with 10M ethernet cable to the router.
Question:
1) Does quality of cable play a part in network traffic speeds at these lengths?
If so which would be a good value buy. I know that some computer enthusiasts here like to spend big bucks here. Need something reasonable.
2) What is the difference between cat5e, cat6 etc? Which would be best for my solution. there isn't going to be lots of patch cables coupled together (maybe 2-3 max). Shielding/interference shouldn't be a major issue.
Question:
