Does RivaTuner lie?
1 May 2007
London
Getting a little worried about the reported GPU temps in RivaTuner. My machine holds a pair of 9800GX2's inside.
All 4 GPU's are clocked at 667 core / 1072 memory / 1729 shaders with 100% fan speed. At first I figured the second card (GPU 0 and 3 in RivaTuner) was not getting enough air (odd because there's a 1 inch gap on either side of both cards) so I swapped them about. Same temps, so I took the cooler off the hot one and put some MX2 on the GPU core, took a whole 3 degrees load off.
Is/was it fairly common for some cards produced to be hotter than others or can this be counted as a bad early sign?
The card in the top graphics slot will always be the hottest one due to the amount of space left inbetween for cool air to get sucked into the fans.
As heat rises, it will affect anything that is up there. Heat from the back of the bottom card rising up to the top one.
Since you said that you swapped the cards around and get the same temperatures, that is pretty evident of it.
Check and sort out your own case cooling too. Maybe add a couple side fans to blow onto the graphics cards.
You do have 2x Dual GPU cards too, so it would be quite normal if they get too hot if you have inadequate case cooling.
See, that's the funny part. The hotter GPU was up the top, but now it is the lower one. I'm using a lian-Li V2000 with a 2000RPM 120mm front intake fan inline with the 2 cards and a 120mm exhaust fan drawing the hot air given off from the cards directly out the side. just seems wrong there being a 16 degree difference in core temps all folding the same work units. As you can see from the other card, they're equal.
Even on two identical cards there may be some difference in the fabrication process so diffence in heat production/dissipation. The thermal diode on one core may also be a bit iffy...
