Does Sky Go work on custom roms?
17 Oct 2002
London
I'm thinking about getting an an LG G Pad 8.3 and using sky go on it while away from home (tethered to my Nexus 4 & still to be purchased one plan (damn those price hikes)).
Does anyone know if Sky Go will work if I install CM or PA then unroot?
there's a root-hiding xposed module, give that a try
The RootCloak plugin says it won't work with Sky Go as they use native libraries which can't be intercepted by the Java based Xposed framework.
As far as I can tell all the root related paraphernalia like SU and BusyBox need to be purged from the device. Unfortunately I can't tell if it's as simple as unrooting and making sure those apps are uninstalled.
