Does such a cable exist micro sd card to usb
27 Jun 2008
I have games on a micro sd card on my Nintendo switch but the price of the sd cards compared to a usb stick is a lot. I was wondering if there is a cable with a soldered on sd card on one end and a female usb on the other so I can put the games on a usb stick and plug the other end of the cable into the micro sd slot on the nintendo switch ?
Short answer is no.
It is theoretically possible on a case by case basis if you have a good understanding of the specific SPI interface and build a custom adapter.
Aren't USB sticks just as expensive though? Shocked last time I looked for a 256gb+
