- 24 Nov 2011
Hi OcUK.
Does anyone know if there is such a thing as a front panel temperature display that does NOT take it's readings from probes inside your case, but rather from the built in censors on your components, á la Speed Fan, Real Temp et al?
I have the Scythe Kaze Master, but the temperature readings on it are fairly meaningless.
Thanks in advance!
Thanks in advance!
