- 10 Jul 2006
I am looking for a decent text editor that has the following:
- Tabs for open documents.
- Tree view side bar.
- Syntax highlighting for major languages.
- Line numbers
- Intelligent auto-formatting*
- Persistant code collapsing (so if I collapse code and then close and open the same document, the code is still collapsed)
Preferably:
- Able to login to my server via SSH and edit files directly on there.
* I want it to format my code/text such that if it exceeds 80 characters it puts the text automatically on a new line and indents it automatically. For instance if I was doing HTML:
...I'm now editing that sentence and it will be longer than 80 chars so it does this:
Or if I was doing javascript, this:
would go to:
- Line numbers
Preferably:
		Code:
	     <p>This is the sentence.</p>...I'm now editing that sentence and it will be longer than 80 chars so it does this:
		Code:
	     <p>
        This is the sentence. I have no added some extra text jazz. Pretend this is longer
        than 80 chars and it goes on a new line
     </p>Or if I was doing javascript, this:
		Code:
	   myVar += areallylongvariablename + anotherreallylongvariablename + "Some more stuff";would go to:
		Code:
             "Some more stuff";
