Does the 8600GT need a power cable?
5 Oct 2008
I have one, won't be installing it for a week or so, well there is no 4 pin floppy type socket on it but it does have a small interface part on it at the top ( see picture) if this isn't a power interface what is it?
my.php
http://img145.imageshack.us/my.php?image=albatron8600gt256pspcrw5.jpg
cheers.
the top connector is a sli connector. if its an 8600 it will most likely need a 6 pin connector from your power supply.
a good 400 watt psu should be fine. some 350's may also get away with it, depends on the 12V rail of the psu.
this is for SLi only - if you see the 6-pin box box on the other side of the card then use for PSU cable but without it then no need cable from PSU -- my 2 of 9600GT XXX has 6-pins connector so I already plugged 2 cable from PSU to each card and used SLi bridge.
