Does these look right?
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
Just went from 1G to 2G.
Had 1 pair of 512 x 2 of Geil PC3500, added another 2 sticks of OCZ PC3200 (with a better timing). Checked CPU-Z, notice performance mode is not running? And the OCZ is on 166mhz/200mhz??
Just wondering is it normal? It is on a P4 3.2 Northwood/P4C800-E motherboard.
Often happens when you have all 4 sticks occupied or have mixed brands.
Doesn't mean it won't run 200Mhz though, so I'd try manually setting memory speed to 200Mhz in BIOS and set timings to 2/3/3/6 matching the slower Geil sticks.
I am wondering if i am reading it right, is it running at Geil speed? As in 200mhz? I am confused as it is showing 166mhz and 200mhz.
If they are both running at 200mhz then i am happy with that.
The memory speed settings is not in there, it should be under the "Jumper Free Configuration".
Your memory is running at 166Mhz. The page where it shows both 166 / 200 is to show you the default SPD timings at relative speed and not the actual speed it is running at.
