- 15 Mar 2010
- Bucks
theres a table in a db with records containing a unique id, names, addresses, course codes, accomodation numbers, telephone numbers etc, the questions are:
a. Adapt the database to conform to at least 1NF (First Normal Form) and structure the database into a relational model.
b. The database includes one form (called FrmStart) with a visible command button (CmdButton) when the user clicks on the command button a message box appears with the text ‘hello world’ and the form closes (not saving) followed by a different form opening (called FrmNext) How would you write this in VBA?
now I dont want answers but the actual questions make sense yes?
essentually A is looking for non repeating info split into tables , then linked together by the end of it you end up with it in 2NF if done correctly.
and B is declaring the subroutine, msgbox, and docmd.openform baring in mind to use acsaveno when closing.
