- 11 Oct 2005
- Derbyshire
hi wonder if you can shed some light on a device that may excist.
I dont know if they do, but if they do it would be great.
I play the Piano and I have a Yamaha Clarinova, Basically a Electronic Piano with a lot more to offer.
Now it has a floppy drive on it which I use for to load midi files, to be able to play them on the piano and edit/record etc.
Later models of the clarinova now have USB as well as floppy.
Mine only has floppy, so i was wondering is there such a device as a floppy disk I can insert into my piano which gives me a USB output. SO in theory I could put the floppy in and insert my USB Data pendrive into the USB output from the floppy and have more capacity.?
Hope this makes sense. Basically a floppy disk with a USB socket on the other end.
Thanks
Thanks
