For those asking, it will be used for simultaneous drive backups...hence the need for greater bandwith. If I've got 20 drives all backing up, I'm gonna need a bit more than an unsustained 480Mbps![]()
Unless it is a very special device I can't see the USB >SATA interface going any faster than USB speeds.
Could you not house them in another PC in removeable caddies?
You need to lay out exactly what you are planning, as im sure there are better options than connecting multiple USB to SATA.
1. USB and SATA aren't directly compatible.
2. 480Mbps is only theoretical, in practise IEEE1394 (aka Firewire) is faster.
Gigabit LAN has theoretical speed of ~125MBbs but in practise it's slower (~75MBps in some reviews) so two slow HDDs could already saturate that.
Only way for full performance is eSATA with lot of ports...
(but neither that helps if backup source is one drive)
