- Front Cooling: 2 x 120mm Fans (optional)
- Rear Cooling: 1 x 120mm Fan (included) or 1 x 92mm Fan (optional)
- Top Cooling: 2 x 140mm Fans (optional) or 2 x 120mm Fans (optional)
- Bottom Cooling: 1 x 120mm Fan (optional)
Source: http://www.overclockers.co.uk/showproduct.php?prodid=CA-019-BX (your own link)
You tell us..![]()
I'm guessing it does and where would you say it is best to fit the fan on the case for the best cooling
Well since the 140mm fans only fit in the top.... I would say the top![]()
