Does this look right (Have I done it properly)
17 Aug 2005
Swindon
Using that crucial ballistix tracer on a GA-P35
Your RAM is running at 734mhz. If it's DDR800 then it's slightly underclocked but running it at 1:1 with the CPU would make up for that. If it is DDR666 then its overclocked. If its DDR800 then try setting the latency to 4-4-4-12 or 4-4-4-15 to make up a little for the underclock. Because it's running slower then its rated it might be able to run with the lower latencys but as always do an orthos check.
