Nazca said:How do I change the timings? On a Gigabyte DS4 mobo.
It's at 2.22V at the moment. I've done a few tests, and it seems stable. Was going to do a Prime BLend overnight to make sure, but I'm concerned with the timings.
Minstadave said:You'll need to get yourself in the BIOS
2.2V is fine, stick with that while you play with the timings.
Nazca said:Sorry for being a nub (first OCing experience) but could you tell me what it would be under. I was searching for some option to change the timings in the BIOS but I can't seem to find one. What would the setting be named?
Thanks![]()
Minstadave said:Probably under the advanced chipset page if I rember Gigabyte BIOSs.
Nazca said:I just went into the BIOS. Under PC Health at DDR18V it says Failed.
How do I resolve??![]()
