Does this look right?
20 May 2007
Stoke-on-Trent
Hi guys,
I fitted some roll center adjusters today but was just wondering if the gap in the rubber boot is normal?
Looks like it should go further into the knuckle but that's as far as it will go.
Well the castle nut looks to have lined up with the split pin/r clip okay, so I'd guess it's fully seated, but you are right - it doesn't quite look fully seated from the bottom, does it?
