yes, google is your friend
* Screen Size: 22" Widescreen
* Screen Resolution: 1680 x 1050
* Response Time: 5ms
* Brightness: 300cd/m2
* Contrast: 20000:1
* Main Specifications:
* Screen size: 22" Wide
* Brightness (Typical): 300 cd/m2
* Contrast Ratio (Typical): DC 20000:1(1000:1)
* Resolution: 1680*1050
* Response Time (Typical): 5ms
* Viewing Angle(Horizontal/Vertical): 170/160 (CR>10)
* Color Supported: 16.7M
* Video Signal: Analog RGB, DVI
* Sync. Signal: Separate H/V, Composite, SOG
* Connector:
15pin D-SUB, DVI-D
* Power consumption: 45 Watts
* Stand by Power (DPMS): <1W
* Type: Built-in
* Plug & Play: DDC 2B
* USB powered hub option: No
* Mac compatibility: Yes
* Multimedia Speakers: No
* Wall-Mount: VESA 100mm
* Cabinet Color: High Glossy Black
* Special Features: MagicBright3, Off timer, Image Size Color Effect,Customized key, MagicWizard & MagicTune with AssetManagement, Windows Vista Premium,DVI with HDCP
* Product Dimension (With Stand, WxHxD): 516.8mm x 421.3mm x 208.7mm
* Product Dimension (Without Stand, WxHxD): 516.8mm x 372.7mm x 71.2mm
* Shipment Dimension (WxHxD): 596mm x 440mm x 132mm
* Product Weight: 4.8
* Shipment Weight: 6.2
* Type: Simple(Ball Hinge)
* Function: Tilt
