does this motherboard do SLI properly?
15 Feb 2011
Slough
my friends local computer store is offering what could be a better deal than overclockers on his new PC. i just need to get a couple of things confirmed.
my main question is, will the motherboard he has been given, the Foxconn P67A-S Motherboard Intel Socket LGA1155 P67 (B3 Revision), do SLI in x8/x8, x16/x8 or x16,x16.
had a quick look, and i havent found anything about it. thanks for any help
Hi there,
Unfortunately, that motherboard doesn't support SLI (so dual nvidia cards running in SLI is not possible), however it does support crossfireX at x8/x8 speeds - which is as fast as you can get on P67 boards without adding a NF200 chip (these boards are very expensive).
