So basically I have 2 PC's in bits around me, and I believe that the PSU is causing the issue. First the bits.
1st
Asrock z68 Extreme 4 gen 3 Mobo,
i5 2500k
Kingston hyper 8gb ram 1600mhz (2 sticks)
2nd
Gigabyte x58a udr (Was RMA and returned a few days ago)
i7 920
Patriot Viper 6gb RAM 1600mhz (3 sticks)
Both parts are being built out of case with Intel stock cooler to test if they are working. Both are using Asus 5850 direct CU GFX card and both tested with my HX 750W PSU from Corsair.
The problem.
Same issue with either build. As I said Ive build out of case to test parts. When plugged in and powered up the PSU fans, GFX card fans and CPU fan all start to turn. Within 1 second the fans stop and the power dies. Exact same issue with both builds, neither build reaches post.
The only common components in either build is the gfx card and the PSU.
Im guessing the PSU is at fault here but any other suggestions as to possible cause?
Thanks
1st
i5 2500k
2nd
i7 920
The problem.
Thanks
