Hi
I'm getting random BSOD's with my new build. I first suspected my graphics card drivers but now I suspect it might be my memory.
I reinstalled XP 32 SP3 and have only installed chipset drivers and XP updates, So I ran graphics card in VGA mode to see if that stops problem - it didn't.
- I have tested temps and cooling, all seems fine.
- Setting DRAM voltage to 1.9V as recommended
- Run memtest86 twice, each with 3 passes - found no problems.
Then I put my old Corsair PC2-5400 RAM in to see if BSOD's continued, and so far, for about 1 week they haven't!
Is it likely I have bad parts then?
PS if I installed XP using bad memory, but then switched to good memory some time after, would BSOD's continue to occur?
PPS System:
Intel E8400
Asus P5Q
Corsair 4GB PC2-6400
ATi HD 4850
Asus Xonar DX
Antec TP2 550W
XP Pro 32 SP3
PPS System:
Intel E8400
Asus P5Q
ATi HD 4850
Asus Xonar DX
Antec TP2 550W
XP Pro 32 SP3
