- 21 Feb 2003
Hi everyone, I've been a member here for a while now buts its been a long time since I posted anything.
I'm about to upgrade my 4 year old Dell with a custom made pc. I had planned on a 24" iMac but a friend has just built is own pc thats much faster than the Mac I was looking at and was about £600 cheaper, so I've got to go the pc route again as I want as much performacefor my money as I can get right now.
Basically this pc will be used mostly for photoshop as I do a lot of photography and am about to buy a Nkon D2X which produces 18mb or so RAW files.
Now my friend has just built the following spec pc for just shy of £700:
Intel 2.4 C2D
ASUS P5B Deluxe 775
2 x Corsair value 1GB DDR2 667
Asus GeForce 7600 GS 512mb gfx card (silent series)
Maxtor 320gb SATA2 Hard Drive
Silent hard drive cooler (big heat sink that sits over the hard drive)
Sony DVD writer
and a case to put it all in.
Now I have had a play with his pc and it is very very fast. It will open up a D2X raw file in CS2 in about 3-4 seconds (including booting CS2!) which is way better than my long in the tooth P4 that takes about 20 seconds to open a smaller D200 file.
So I know I like the performace this system offers, but I'm just wondering if there are any improvements that can be made but keeping under that £700 figure? I just want to make sure I am getting the most performace I can for the money.
With the gfx card for example I see there is a 7600GT version with only 256MB that is slightly more expensive, would that be better than the GS series with 512? Its all a bit of a mine field to me as I haven't been in to the computer upgrading thing for years!! The system will be hooked up to a Dell 24" monitor.
Ulitmate requirements are:
1) Photoshop speed, must be fast with large files as I can sometimes be looking through up to 500+ shots after being out for the day with the camera. I will be upscaling images to 5000+ pixel TIFFS (50mb+) sometimes.
2) Little noise, I don't want somthing with tons of fans making loads of noise. The system above is very quiet which is another factor I like about it.
3) £700 tops.
I'm all but set to buy tomorrow so any advice would be greatly appreciated, even if its just to say the above system is a good choice.
Thanks everyone
Intel 2.4 C2D
ASUS P5B Deluxe 775
Sony DVD writer
3) £700 tops.
Thanks everyone
