- 5 Nov 2004
As the title asks really ?
Fstop11 said:How do you do it ?
csmager said:And, fairly obviously, make sure you have a spare partition or drive with at least 15Gb free.
That how big the vista install is? Or are you adding swapfile space there as well?It does take up quite a bit, but not quite 15Gb. That's just what MS recommend as a minimum.messiah khan said:15GbThat how big the vista install is? Or are you adding swapfile space there as well?
And I'd guess even the final Ultimate version will too.tolien said:It's probably worth pointing out that the Vista Betas are the Ultimate version, the "lesser" versions should consume less.
For starters, it's not on general release yet. When it is, you have 14 days to activate... and then I think there may be a time limit of 180 days, but don't quote me on that.greenlizard0 said:Are these the thangs that have a time up thing attached to it? Like you can try it for a bit, and then it locks itself up?
Should work either way. I installed off the HDD using DaemonTools first time round, then I formatted completely and booted off a burned DVD. Both worked fine.Fstop11 said:Is there a specific way to go about installing the Beta 2 of Vista. Burn it to dvd and it moans about some file it cant access. Run it from your hard drive and it almost completes and then tells you that the install was not sucessfull and it returns things as they were using both upgrade and clean.
Did you encounter an error regarding the Silcon Image Sil 3132 SATALink Controller ?csmager said:Should work either way. I installed off the HDD using DaemonTools first time round, then I formatted completely and booted off a burned DVD. Both worked fine.
As I don't have one, no I didn't. If you're encountering an error, you might require additional drivers to install (like installing XP). In XP, you press F6 to add new drivers. Not sure how it works in Vista, but it might be similar.Fstop11 said:Did you encounter an error regarding the Silcon Image Sil 3132 SATALink Controller ?
Well I dont have another Pc so thats not an option. I have tried to update the driver but It just doesnt work with a latest one either. I can try without one installed at all.csmager said:As I don't have one, no I didn't. If you're encountering an error, you might require additional drivers to install (like installing XP). In XP, you press F6 to add new drivers. Not sure how it works in Vista, but it might be similar.
If that doesn't cause it, then it might just currently be incompatible. In which case remove it, install on another HDD Drive on a different controller, or try another PC.
