JustinB said:Yes it supposidly does but i doubt you will want the cpu in 8 years time anyway.
Have a search on the forums for electro migration.
Sorry not sure about voltages on the opty but i wouldnt like to put more than 1.5V through my 4400 on water. Although 1.55 would be ok i Guess.
Just the heat!Greyhound said:Does higher voltage shorten a processors life or is it just the heat that typically comes with higher voltages
I don't think that is correct. The heat will get it everytime, that is why manufacturers publish thermal guidelines. . however I do agree that overclocking will probably shorten the lifespan of said CPU (live fast die young sorta thing!) but this is a moot point as I don't think anyone will use a CPU for more than five years.welshtom said:yes voltage will kill it and shorten its life
Big.Wayne said:I don't think that is correct.
Tim said:It is, too much voltage even when running at 30c can kill a chip. You're straining the silicon.
3oh6 said:voltage is your friend
*warning...increasing the voltage may stabilize your system...oh, and it may also void your warranty*
most people i talk to are scared to increase the voltage to their components as manufacturers warn against it and will void warranties if it is found that you increased the voltage from their recommendations. raising the voltage too much can also result in hardware failure but if you know how much is not too much, then you can safely play with the juice. increasing voltage is the only way to get a large increase in performance, without increasing voltages you will be drastically restricted in what you can get out of your system. there are really only 3 voltages that could/will be adjusted when overclocking the system...
welshtom said:correct.
try putting 2.1v through an Athlon 64 cpu cooled by LN2. it will die!
.::lawrywild::. said:I've seen the Germans put 2.2v through a water cooled A64, BEAT THAT!!
Mr Mister said:pfft ive got 1.67v through an opty on air, it will shorten the life of the chip by quite a bit but i wont be keeping it very long anyways. Especially with the looks of the new intels!
Off topic, ive been invited out in Ilkeston next weekend, might go to Notts instead.kimandsally said:Especially with the looks of the new intels
No swearing on the forums please![]()
pegasus1 said:Who would keep their CPU for 15 years anyway, personnaly i would rather have better performance for 2 years.
mcmad said:Electromigration basically can break down the conductor (effectively etches it over time)
then an overheated/overvolted CPU might die very quickly. It's a luck of the draw thing.
