Does water ever drop below room temperature
Caporegime
1 Dec 2010
Welling, London
Daft I know but I'm not sure.
If you heat a tank of water to above room temperature and then then let it cool, will it drop below room temp or will it drop to room temp and then stay there!
Thermodynamics yo
Unfortunately, pure mechanics doesn't always translate well to the real world. I have no idea. There may be a buffer zone, and it could be either exactly, slightly above or slightly below. Obviously it won't drop significantly or refrigerators wouldn't need power :P
What unknown variables are there? Does evaporation have any net effect on temperature?
Provided there are no outside forces acting upon the system it will reach thermal equilibrium.
Obviously if room temperature increases at a certain rate it will warm faster than the water so the water would be below room temp until it again reaches equilibrium.
depends of the temperature/humidity of the room.
Under certain circumstances evaporative cooling could eventually result in the water becoming cooler than the air temperature in the room.
What he says, would also be accelerated if there was breeze over the surface of the water.
It depends. It is not a lab that process will not be happening in isolation. Theoretically presuming no other factors an equilibrium would be reached. There never are no other factors though!
Bear in mind that 'room temp' may not be static throughout the room, but I would expect it over the long term to get close to the immediate ambient temperate assuming that aren't any extreme conditions.
It will go below room temperature if you let it cool in a fridge. Hope that helps.
The real question is, will the water take off on a treadmill and does it equal .9r?
is the water in a pressurised container or a vacuum?
Is it on a treadmill?
D.P. said:
If you cut it half do you get 2 waters?
